Working MIDI devices
we seem to have quite a few topics detailing usb midi devices NOT working.
I think it would be useful to have a list of devices known/tested to WORK
this might be useful for 4ms in the future to include on the website somewhere… but here is a good place to capture experiences.
to keep this topic clean/simple , some ‘guidelines’ :slight_smile:
  • ONE post per user, with ALL devices.
    where necessary, edit your post to include new devices that you have found to work
  • do not repeat existing entries.
    no need, to repeat those that someone else has already listed
  • no discussion, just listing of devices
  • do NOT include devices not working.
    create a new topic for devices you are having issues with
the last point is very important, there are lots of reasons why something may not work, so should be explored away from this topic.
ofc, once you get it working, then you can list it here :slight_smile:
testing regime / patch
this is how I tested, I used the simplest way possible to avoid any other potential issues!
all done on the MM itself !
  • create new patch
  • add Resonator (Rings)
  • Resonator : v/oct - midi map, Note: Pitch
  • Resonator : strum - midi map, Note: Gate
  • Resonator : odd/even - panel out 1/2
note: by default midi pitch/gate mapping are to midi channel 1.
MM Limitations
  • direct connection only
    usb hubs do not work
  • MM is a USB host
    so only USB midi class compliant devices are supported.
  • Squarp Hapax, link
  • Squarp Hermod+, link
  • Expressive E Osmose, link
  • Blokas MidiHub, link
  • Embodme Erae Touch Mk1, link
I used the usb-c → usb-a adapter supplied with 4ms MM where necessary.
Blokas MidiHub I used for midi din (and midi trs via adapter) to usb-b with a few different instruments.
These work for me:
Currently available:
Korg SQ-1
Korg SQ-64
Cre8audio NiftyKEYZ
No longer available but may be owned by others:
Sensel Morph
Livid controllers
Launchpad Pro mk3 works.
These work for me in OP test setup:
  • Arturia Beatstep
  • Arturia Beatstep pro
  • Arturia Keystep Pro
  • Arturia MicroFreak
  • Arturia Keylab25 (out of production)
  • Novation Xstation (out of production)
  • Midiplus Smartpad (not sure of note pattern on pads)
  • Akai APC40 - (there is no note mode - buttons trigger notes but no meaningful pattern (that I can hear) to notes)
All via usb to 4ms usb dongle to MM.
the following worked for me using the 4ms provided usb-c male<>usb a fem adapter:
arturia keylab 61 (can be powered by mm via usb cable)
behringer bcr2000
behringer U-Control UMX25
keith mcmillan qunexus K708
korg minilogue
korg nanokey2
korg nanokey studio
korg nanokontrol studio
korg nanokontrol 2
TENINYU USB to MIDI Cable Converter adapter - great for connecting any din/trs devices (or if you have 2 of these adapters, you can connect them with DIN couplers and control mm via IOS apps or osx/windows)
1 custom midi knob box (uses arduino leonardo)
1 custom midi fader box (uses arduino leonardo)
Roli Seaboard Rise 25 Works in Single Channel mode.
AKAI Professional MPK mini first version WORKS
Anyone tried an OXI One yet?
Yes OXI one is working fine! in USB mode and midi TRS…
Amazing - thank you!
FaderFox UC4
Elektron Digitone (but only with a specialised Din > usb3 cable).
However, Usb B to Usb C cable or Usb B to Usb A using supplied adapter do not work.
Faderfox EC4
Electra One Mk2
Clarification on devices, they only work when they are in device mode as Meta is only able to host and not be a device itself, which may seem obvious to some but is a bit limiting when working with a USB host router and trying to send midi to the Meta from the router
So here’s my list for working:
Launchpad pro older version
Launchpad pro mk3
Squarp hapax device port only
Oxi one device mode only
Midi Devices not working:
MRCC hub
MioXL hub
Plinky v3, link
Hi, I’d be interested if someone got a torso t1 talking to MM via usb midi. It shouldn’t be that hard, I’m just too stupid I’m sure.
as per OP, I think it would be better if we keep this topic for listing working devices. as a ‘reference topic’
questions / non-working devices will tend to dilute this ,and I think warrant a separate topic to have meaningful discussion etc.
aka, dont be afraid to create new topics :slight_smile:
Late reply, but how do you connect TRS midi to the MM? The MM doesn’t have a TRS midi jack…
Need to wait for the expander for that….
Teenage Engineering EP-133 KO-II
Polyend Tracker mk.1
Endorphin.es Shuttle Mate (to input 5-pin MIDI via the supplied usb-A adapter)
Yep sorry, no TRS on MM TRS was working on the OXI coral… :wink:
