What are you working on?
Working on a new mixer module family for Submit
After using the 4ms MetaModule for a while, I found myself missing a mixer that works the way I think. So I started building one, designed specifically for the MetaModule, with VCV Rack support as well.
The idea is simple: chainable stereo mixer modules that scale with your patch. Need 4 channels? Use two. Need 8? The 4ms MetaModule recently added support for multiple cables per port, which opens up a lot of new possibilities. This mixer takes full advantage of that, making it easy to send multiple channels to a shared FX.
Chain the core mixer module
  • 2 stereo channels (mono normalled)
  • Pre-gain per channel
  • Volume fader with VU indicator
  • Pan per channel
  • 2x FX send per channel
  • HPF (low cut) per channel
  • Mute per channel with CV input
  • COMP/CV insert per channel
  • Chain in/out for linking multiple modules
  • Stereo FX send/return
Squeeze sidechain compressor insert
  • Gate or audio input (switchable)
  • Threshold, ratio, attack, release
  • Connects to COMP/CV jack
Shape EQ/filter insert
  • Connects via chain in/out
Master intelligent output processor
  • Transient shaper, compressor, limiter
  • Final stage of the chain
Designed with the 4ms MetaModule in mind, compact, efficient and minimal CPU usage.
