No audio passing through airwindows module
no audio passes through when you first hit play on this patch. and if you got to adjust the dry/wet set to 0%, you still won’t hear audio. but after you go to actions>initilize, the audio will start passing through it.
firmware dev 12.2, plugin v2 dev-12.0
airwindowsnotworking.yml (2.8 KB)
Thanks, yes I experience this as well. A while back I noticed a few uninitialized variables in the Airwindows code, so I’ll check for that.
Ok, I found it – there was a bug in the way patch files are saved from within MM. If the parameter IDs have gaps, then the ID in the patch file would get off. Airwindows modules have gaps in their parameter IDs, and it so happens that Input Level and Output Level have a gap before them – so the module would be silent. In the patch you attached above, doing a Reset would just turn these two sliders up – turning them up manually works just as well.
Anyways, I’m making the release today hopefully!
awesome ty dan! look fwd to being able to use the airwindows ones again…
