Firmware v2.0.0-dev-12.5
Just released v2.0.0-dev-12.5: MetaModule | downloads
(Also, CVfunk has been updated to work with the new graphics, make sure to update that plugin)
This speeds up graphic screen a lot. It’s fast enough now that we can display the screens on the whole patch. Frame rate is split up between the number of visible screens.
This will probably be the last release of the dev-12 series.
Unless there’s a minor bug fix soon, the next release will be dev-13 which will add support for native plugin graphics. We’re almost there to v2.0!
Major changes
  • Draw graphic screens on PatchView page
  • Optimize graphic displays:
    • Support filled concave polygons
    • Big performance improvements
    • More accurate rendering
    • Clip to widget’s draw region
  • Allow mapping MIDI Note gates (on/off) to params: #471
  • Support Plugin aliases (multiple plugin names in VCV => one MM plugin): #470
Fixes and minor improvements
Updated as normal but loading SickoCV plugin hung the module/screen. Something broke?
Stays this way, other plugins loaded fine.
Maybe @sickozell can have a look.
You’ll need the latest SickoCV plugin
Hi, I updated to v0.11 yesterday. This issue should be fixed
Thanks, my MM is good as gold again.
OK, found an issue: Wi-Fi does not work reliably when some MIDI controllers are plugged in. There doesn’t have to MIDI running, or MIDI in the patch. It just has to have a physical USB cable plugged into the MetaModule, with the other end going to a MIDI device (even if the device is inactive – it just matters if it’s plugged in). This goes back to at least dev-12.0 up to dev-12.5.
I already have a partial fix – at least it’s good enough to get Wi-Fi to work again, but there are some more improvements needed in the USB driver.
