MM stops with less then 40% usage
OK, I tested it here and I see that every so often the Morpheus consumes a lot of CPU. I looked through the code, but didn’t see anything obvious…
But since it’s infrequent, setting the block size to 128 or larger seemed to fix it.
Also, the latest firmware I just posted (v1.6.4) includes a feature where you can allow momentary CPU glitches without having the audio stop.
