Clouds / Granulation Spectral Madness Crash
Running 2.02 When switching to the alternate mode I hit 95%+ cpu, I have it on mono / 1sec ( the lowest setting ) no modulation in’s or other modules loaded.
I can still navigate to various menus but the mapped knobs no longer work even when navigating to them directly and trying to adjust.
I tested and I am getting OVER messages at all sample rates and block sizes. Looks like a bug that has been there since 1.x:
Hi - Have you tried the Sanguine Mutants Nebulae (Monsoon clone) or the Etesia module (Clouds Parasites) both of which include the Spectral Madness mode also ?
I am running the Nebulae module on my MM now in Spectral mode 48k / 512 at 37% CPU … I do get some UI hanging sometimes when I am looking at the module menu, but it seems to work…
I lowered some of the FFT sizes so that these algorithms could run a bit better on the MM. I thought they still sounded pretty good at significant CPU savings, give those a try instead.
