Greetings!
I’m trying to chop some breaks using the MetaModule on firmware 2.0, and sequence the chops internally within the module for some jungle music. I’d love to know if anyone else is doing something similar. What are you using, and how are you approaching it?
Thanks in advance!
Hey - been trying out a few things for something similar .
There’s a few decent sample players but nothing which seems that great for sample chopping up yet. Been doing some cool stuff with the Voxglitch Grain FX and drum loops though!
I have not used it but does the Voxglitch Autobreak add any value to the discussion?
Works ok and keeps loops in time with gate input, but not super precise for cut ups. Probably work best running a sequencer in time with the gate trigger and using CV into the ‘Sequence’ input to trigger different sections of the loop (hopefully) in time.
Ended up going down a rabbit hole and building this - which can work with several different loops and get pretty wild very easily.
And you can find the VCV and MM files for it here:
this sounds p great
Thanks!
Be good to see what people do with the patch - can be developed further as using less than a third of the processor at present.
Autobreak Studio specifically is the one you’re looking for if you want to go the voxglitch route. It’s a 16 step sequencer interface and is excellent for per step modulation Voxglitch Autobreak Studio Patch - #3 by Ross
