Does anyone have Ableton Push and Metamodule working so that Push is able to send MIDI via USB to MM?
I’ve always been terrible at the whole host/device logic, but if I understand it right, a USB-C to USB-C cable should work? I had problems getting it to work at all.
Yes it should work fine. You can use VCV rack’s MIDI modules for easy mapping. Whatever the mapping is in VCV will transfer over to MetaModule. When you load the patch in MetaModule all of the MIDI modules will disappear but their mappings will remain. Please let me know if you’re having any issues.
