Wishlist: tiny tricks modules [update: now ported]
i really like tiny tricks modules for all sorts of randomization on the rack, do you guys think it would be possible to port it into mm or would it be too cpu hungry?
https://github.com/thomassidor/tinytricks
@sseemmii Welcome to the forum!
Looks like that would port fine on a quick glance. What are the specific modules that you find useful?
thanks! :hug:
i find myself using these alot in my patches and and couldn’t find anything similar to these. we have the random values module but i need other utilities when using that one.
Modulation Generator x8 (MG8)
Modulation Generator x16 (MG16)
thanks!
@sseemmii I had a go at porting the whole thing (coding agents make it easier :slight_smile: ): Release Tiny Tricks for MetaModule v2.5.4-mm1 · gabriel-roth/tinytricks-metamodule · GitHub
I have not tested it on MetaModule yet! Give it a try and let me know if anything doesn’t work as you expect.
you are amazing! i’ll quickly try it.
They all work pretty good. The modulation x8 module eats up around 15% cpu which is ok. Thank you So much!
