Windows usb midi
Im connection the meta to a windows computer to ee if I can send midi data from /to metamodule but it doesnt not show as a midi device even though I cand send midi to the usb from other devices (Droid, disting etc)
Can this be done?
Is there no driver for windows? Sorry havent tried on a mac yet.
Cheers
i have been able to control the mm from a windows laptop using 2 of these:
both of them were connected t ogether using these couplers:
midi out on the mm doesn’t work yet so you can only control the mm from windows, ios or osx with the adapters above, not the other way around.
Hi!
Thanks for the reply :slight_smile:
Yes I can get it to work with those too (mine the un one from roland).
Just wondering why it won’t work with a direct usb cable connection.
Cheers!
I believe it is because the USB port on the MM only functions as a “MIDI Host”. I don’t think it is possible to directly connect two devices that are “MIDI hosts” via a USB cable. Your computer is a MIDI Host, which means that you cannot directly connect it to the MM.
