WiFi really is magic 😀
Works amazingly well - straight from VCV to filesystem at the click of a button.
Top work Dan & team!
i second this! having used the kvm for a while, the expander really helps remove the clutter as well. edit: and with the new wifi button on the vcv module, it has sped things up (don’t have to mess w the explorer pop up window anymore). hopefully we’ll see an auto reload patch feature that updates the patch on mm after clicking the wifi button in vcv.
shoosh you! I’ve been not messing around with my MM until the Wi-Fi expander is released. LOL
yeah, i just want it to have an auto reload, then i’ll make a purchase for sure.
Flipping the switch when using a KVM switch is pretty quick otherwise and the cable isn’t an issue for me.
also i remember dan mentioning at some point in the past the idea of being able to refresh a patch by hitting the back button to go to the main menu, then hitting the back button again to go back to the patch view and it would reload. auto refresh after hitting the wifi button would be faster better imo, but hitting back button twice would also be better than it is now. since currently we have to hit back button to go to main menu, go to load, locate the patch (sometimes the mm still has the currently running one selected, other times it doesn’t, a little wonky), then back to patch view to hit play- after doing even just that portion on the mm fifty times in a row to get a patch right, certainly gets tiresome
It has been awful quiet on the forum. Everyone must be playing with their new Wi-Fi module! Except me, mine isn’t scheduled to arrive until Monday :frowning_with_open_mouth:
It’ll be worth the wait dude, makes the set up of patches and transfer from vcv painless :smiley:
Mine has be in the Phx area for 2 days now. Says it will deliver Saturday, but it’s being shipped to my work so I wont have it until Monday at the earliest. =\
Hi everyone! Just picked one of these up after seeing it at the Buchla and Friends event. Does anyone know if you can upgrade the firmware using the WIFI module? I tried to transfer the file, but it states only certain file extensions would work. If not I can post in the feature requests. Thanks!
No - patches only, as far as I know.
Plugins work as well! You just can’t see them using the web interface, but just drag and drop into upload and they magically appear on the module. It’s a bit slow for some of the plugins though, depending on size.
I think I remember a post where Dan recommended not to due to the size of them, guessing there’s a risk the transfer could time out or fail?
I agree, it’s to slow. I just transferred everything by SD card.
