Wi-Fi Expander not found by MM
I got my Wi-Fi Expander today an managed to connect it to my Network. Unfortunately the MetaModule does not seem to find the Expander. Under Settings it shows “No Wi-Fi Module found”.
The Firmware is v.1.4.6
The cables are triple-checked
What stupid mistake could I have made?
Red stripe is pointing the same way on both ends of the Wi-Fi ↔ MetaModule cable? Definitely connected to the Wifi header (not the Control Expander header above?)
You could try updating the firmware again, with the Wi-Fi expander connected. Watch to see if it loads firmware onto the Wi-Fi expander.
Make sure to use this one:
https://github.com/4ms/metamodule/releases/download/firmware-v1.4.6/metamodule-firmware-v1.4.6-firmware-assets-wifi.zip
Got it. It works now. Thanks for the advice. Congrats for the great Module development.
Updating again with the expander connected did the job.
