VoxGlitch Ported
It is here.
Note, I didn’t port several modules, including DigitalProgrammer, GrooveBox, ArpSeq, etc. because they have heavily mouse focused UIs.
The exceptions are the Hazumi and Glitch Sequencer - I thought they might be useful to set up off the MetaModule and then import in but who knows.
All samples should be wav files.
Tagging @danngreen - I have one issue - for some reason this specific plugin won’t autoload? It loads fine, it just has to be manually loaded back in every time I restart the MM even if autoload is on.
Really psyched for this one.
Getting CPU overage on Grain FX, will debug.
awesome i have been waiting for satanonaut to be ported but dont see it … also is anyone else having issues with faceplates images not being loaded ?tried to reload and repower but a few modules wont show anything and get that error i am using firmware v2.0.0 dev 13.4
Oops I might have forgotten to put that one in. I’ll update shortly. This is a known bug with 13.4, it’s fixed in 13.5
oh awesome …i love that module so cant wait … ok i figured it was having to many plugins autoloaded quick search through the forum helped appreciate it
FIRE! really looking forward to these grain fx!!
sadly the wav players do the same ram-bloat thing as all the sicko samplers, i.e. a 15mb 48/16 wav will automatically chew up a 64mb slot of ram. so like the sicko ones, really only worth using if you only need to play 1 or 2 longerish loops. maybe thats enough for most folk?
you can certainly get away with more shorter loops (20s or less) with these. but the good thing is these voxglitch ones don’t cut off the sample at 30 second mark like the sicko ones (i was able to load a couple minute longs samples into vg looper)
the cf player module is the only other one i can think of that maybe might work, its based off the biddo canard (which doesn’t have the ram bloat issue) but also cf player doesn’t have those weird gate, trigger or chop-the-sample-in-half bugs. at least when when i just tested in vcv. other than that i give up (until sts comes around) haha
You’re right. It’s so strange. I see some implementation differences but nothing that should be so egregious from Canard. Even Edsaros in Bidoo suffers from this too - but there are so many variables - some of them store copies of the audio for good reason and hard to decipher.
@danngreen is there a trail to follow here that you’d recommend looking into? any ways to profile this on simulator as it seems to always just show no RAM being used
Knock on wood - I might have fixed this. Trying to see if this works for Sickozell as well.
Hey @etcetc, would you mind porting autobreak studio? That’s a module with a mouse focused GUI that has a lot of potential using a set it and forget it approach
im guessing that one didn’t get ported because it requires too much mouse interaction and wouldn’t be work-with-able on the mm. seems the same story for these too:
At first glance it might seem like that but I actually have a patch going right now centered around that module and it would be great for MM. You can modulate the parameters and scenes as macros while keeping the sequences stored in the module. It’s similar in workflow to using a giant step sequencer (which have already been ported to MM).
Superb work with these @etcetc - love them!
I’ve seen some issues with file management in the Autobreak when using the SD card though and wondered if they can be fixed?
  • Files often do not load the first time
  • When the sample slots are full, no new WAV files can be loaded into the slots
Happy to work with you to help debug and figure it out, just let me know :grinning_face:
Can you be a little more specific about the first issue? Is it any file, or files of a specific length? I know that MM currently is a little buggy with larger files on some samplers.
Sure
  1. These are short drum loops so not big files
  2. When using the option to load them they only seems to do so on the 2nd or 3rd attempt
  3. I’ve tried it with quite a few files now and issue keeps repeating
@etcetc do you mind taking a look at this? I can replicate the same issue they’re having with the most up to date firmware/plugin
Yes, will take a look at this
@Ross @InvictusHifi
Ok, so it turns out it was a weird menu issue where simply the selected sample wouldn’t show up after selected even though it was loaded. I’ve updated and released 2.0.1 which should fix this. cc @danngreen
A few other bugs I found that will have to be investigated later
  • Loading folders of samples doesn’t work in wavbank, autobreak
  • Need to move loading samples to an async thread so it doesn’t interrupt playback when loading
  • Certain wavs can’t be loaded
Awesome - thanks for fixing!
