New features/enhancements:
When saving a MM patch, sort modules by row, then column.
When saving a MM patch, typing a filename in the Save dialog box will
automatically be copied to the patch name. Remove slashes, colons, quotes,
and replace dots with underscores. Use “Untitled Patch XXX” instead of “UnnamedXX”
to match the naming on hardware. -
Make knob alias name text color legible, and make box wider in the context menu
Use better color (white) for cursor in text boxes on the Hub
Add “Unmap” to Hub knob menu for each mapped knob
Hide “Wrote Patch File:” text at top of module
Fixes:
- Removed unused Hold jack from Verb module
- Doing Initialize on the Hub properly removes all mappings
- Fix crash when loading a preset on the Hub
- Addressed Save button not working sometimes
