Is there an equivalent module on the MM that does what VCV Router does (ideally the Octal Router)? Basically after a matrix mixer with cv control over scan. Or are there any plans to port these paid for VCV plugins? I can workaround this by using my Livestock Maze module but would be great to be able to do this in MM especially now that I have the AIO.
Did you try 4ms VCA Matrix?
Yeah, that doesn’t do the scanning part, unless I’m missing something you need a cv input per vca. Likewise with the bogaudio one. I’m after having 1 cv input that scans through the inputs or outputs, smoothly. Bit like a crossfader/panner but across more than 2 channels. The Octal Router seems perfect but obvs is vcv rack only at the mo.
Yeah, it doesn’t do scanning. I doubt that VCV will allow any porting of their commercial plugins, unfortunately.
The HetrickCV Scanner does crossfading of 8 inputs (or selecting active outputs, or both). It’s not a matrix mixer, but you could wire a few of them together
Nice one
That’ll do it, thank you.
