VCV MIDI MODULE not responding on META
I tried for the first time to use VCV MIDI to CV / MIDI to GATE with the Deluge
I can see the midi events showing in VCV but it’s not doing anything on the output of the META (I transfered the patch via WIFI)
When I load the patch on META no modules are showed (as expected) and I made sure to launch the patch (play button)
I’m on Firmware v2.1.9
What am I missing?
Thanks!
Just a precision
→ RackCore MIDIToCVInterface module works fine with my DELUGE MIDI setup
Well after rechecking RackCore MIDIToCVInterface module, when I trigger some MIDI ratchet it’s not as reactive as a modular gate ratchet
Don’t know what to change as it’s not a parameter I can setup
MAYDAY :slight_smile:
Ok the midi ratchet works now
To make it work, I added the fundamental GATE and CV MIX module between the MIDI CC module and the META OUT.
Is there another way of doing it directly from the MIDI to CC modules?
