Is it possible to add a CPU guestimator to the VCV Rack MetaModule?
Some sort of thumbnail estimate based on what’s loaded in the patch?
Thank you! LOVE the MetaModule.
I am able to roughly estimate how much CPU a plugin it will use by checking the CPU usage in VCV rack. On my system, it uses around 7-8X as much CPU unpatched at 32K/64 on the Metamodule. You can see what the coefficient is on your computer through testing. As a rule, anything over .5% on my system will be high CPU and over 1% will be very high CPU. As a result, I try to look for plugins that use .1 to .5%.
I’ve been doing math with just the max numbers fairly successfully. Maybe a whisker chart to show the range or something.
If not, completely understand. This is a nice to have with work arounds.
I just had another thought that would serve the same purpose: add another sort option on the module finder to sort by max CPU load.
