Unfiltered Audio Battalion
Just ran across this on Facebook:
First, up, we now have Battalion running on the 4ms MetaModule! If you’re not familiar with the MM, it’s a powerful Eurorack module that is capable of running patches exported from VCV Rack, or patches built directly on the interface. We have the whole Battalion VCV module suite running here. I’ve sent the plugin over to Dan at 4ms, so it should be available from the 4ms portal soon. In the meantime, if you have a MetaModule and want to dive in sooner, have at it! Dropbox
Oh wow. That is great news.
Use this on my iPad & Mac already and it is a BEAST!
amazing. ty for sharing! curious to see how this is to work w on mm. hope also this means other unfiltered plugins (silo!:crossed_fingers:t2:) will be ported
I would love to see Silo!
Wow. Exciting news.
Are you sure? These are not vcv plugins. It’s not even part of modular synthesis paradigm… how the hell would it work in MetaModule? What did I miss?
Yeah, I’m sure. UA, the creator of Batallion, does indeed also make VCV plugins.
“The most exciting addition to the VCV platform is our Battalion drum synth, which was released as the main synth voice and 4 effects, which you can use to build complex patches with even more flexibility than the original plugin.”
From the VCV discord
after trying them out earlier, they work great. loving that the effects modules especially
I’m away from my gear for another week so haven’t gotten to play with them yet- glad to hear it’s working well.
Yes. I know. I do have purchased vol. 1
But I can’t find the Battalion suite in the vcv’s library…
Is it something new that is still not officially available?
You’ll need to take that up with UA. I’m just posting about the MM plugin.
Huzzah! So happy to wake up and see this thread. Yes, the VCV plugin was sent in two weeks ago. I was expecting it to be out before the MM version, but I didn’t want to keep y’all waiting. Once I’m done dealing with some other pressing tasks, I’d like to circle back and figure out which operations are causing the higher MM CPU usage. Let me know if you run into any other oddities. I didn’t have quite as much QA time on the MM as I’d like since the BattleFX release set fire to my inbox.
Now that Battalion VCV has released (as a premium purchase), hoping to see all of these modules officially on Meta soon as well!
i miss the best part of the plugin: the performance section.
@Holofonze Yep! Dan has the MM build so hopefully it will be on the portal soon. In the meantime, the plugin is still available at the Dropbox link in the first post.
@trinita I would recommend adding this to your patches:
Connect an output from there to multiple modules, then use the SHIFT control to send an offset to those CV inputs. That way you can send the same offset to multiple modules at the same time. As a bonus, you can then add CV to the input of the SISM channel to add, say, an LFO instead of just static offsets to all of the listener modules.
I’ve been using the Batallion on the MM that I downloaded from the Dropbox link above. It’s amazing, I’ve used it for my recent live sets and I love how versatile it is, so many different engines, it really opens up a lot of possibilities within a single patch. I even bought the VCV version so that I can edit MM patches in VCV with the Batallion in it. :slight_smile:
Not sure if there’s anyone on this forum who’s actually involved in the development, but I just wanted to report that it does freeze sometimes. I’ve been switching between different engines and settings via midi cc messages mid-song and every now and then the module just stops making sound and the only way to get it back is to reload the patch.
Nevertheless it’s a fantastic addition to the MM.
I’ve also experienced this, unfortunately don’t have concrete repro steps at this time, same usecase as dada. Would be amazing if this could get fixed! CC @trickyflemming
I think I’ve got a workaround - it seems that the module freezes when I cycle through engines using the knob. However if I send a SINGLE CC message with the value of the corresponding engine, then it seems to be stable. I programmed single cc messages in y sequencer to change the sounds and it’s been solid over the last few gigs.
