Switch positions
Hi, not sure if this is the right category so please move it if necessary. I’m trying to map the Interzone module and notice that the switches that are in a vertical orientation are weird (to me at least). When I assign a knob to one of the switches, you have to turn the knob clockwise to put the switch in the up position and anti-clockwise to put the switch in the down position. To me this is counter intuitive and I know that to overcome this you just change the polarity in the knob settings but when you do this, the screen knob then displays it backwards. If that makes sense?
I’m assuming that this may be something to do with the way the US switches work i.e. up for on and down for off which is the opposite from the UK at least.
Could this be resolved with a global switch setting?
Cheers
