Submit — Drift, Impact & Chrono -> MetaModule Port now Available!
The Submit collection is now available for the 4ms MetaModule hardware! (Beta) All three modules have been ported and tested on hardware.
Download Submit-v2.1.mmplugin and copy it to your USB drive or SD card.
Installation:
  1. Download Submit-v2.1.mmplugin
  2. Copy to USB drive or SD card
  3. Load via MetaModule Settings → Plugins
Built with MetaModule SDK v2.1
I’m releasing my first-ever VCV Rack modules as part of the Submit collection.
Learned a lot building these, and I’m already working on new modules to come.
Drift: Voice Module
A compact all-in-one voice combining oscillator, wavefolder, slope and contour.
  • Triangle oscillator with overtone shaping
  • Wavefolder with dynamic timbre interaction
  • Slope generator (also works as LFO)
  • Contour envelope with full shaping
  • External dynamics input
Impact: Kick / Percussion Synth
A dual-engine drum module with distinct characters:
  • PURE: additive synthesis with harmonic → inharmonic control
  • HARSH: FM-based engine (clean → aggressive)
  • Noise layer (Dust / Crunch / Rumble) with stereo character
  • TAIL (noise length) + FOLD (distortion)
  • CV control + attenuverters
  • ACC input + V/OCT tracking
  • Stereo output + built-in trigger (TRY ME)
Chrono: Tape Delay (updated)
A delay inspired by classic tape echoes, focused on movement and character:
  • 6 tape head combinations (rhythmic variations)
  • TAPE control: hiss → wow/flutter + dropouts
  • Tape-style DRIVE saturation
  • SURGE (freeze + bloom)
  • BREAK (tape stop effect)
  • Clock sync + divisions + head offset
  • Stereo spread control
  • Full CV/Gate control
  • Stereo in/out (~0.6% CPU on Apple Silicon)
Download
Really looking forward to having some time at the weekend to try these out.
Have you considered posting this somewhere on the VCVRack forum too ? e.g. Development - VCV Community . You will maybe get more views and testers on there than here …
Thanks! Really appreciate it.
Yes, I’m planning to post it there as well. I like to share things here first since I’m also aiming to bring these to MetaModule soon, and it’s always nice to get some early feedback before posting on the bigger forums. This is my home :wink:
Thanks for the tip :slightly_smiling_face:
these are all looking/sounding great so far!! really enjoying chrono
Awesome, will mess around with them today! Cant wait for the MM port too!!!
Dont know why but I can’t see it in my library. I reinstal VCVpro, I put it in the dir that is said in the Help menu “Open file location”. I googled it for solution that I tried without result.
A few things to check:
  1. VCV Rack version — make sure you’re running 2.6.x (Help → About). The plugin was built with SDK 2.6.6.
  2. Download the right file for your platform:
  • Windows: Submit-2.8.0-win-x64.vcvplugin
  • Mac ARM (M1/M2/M3/M4): Submit-2.8.0-mac-arm64.vcvplugin
  • Linux: Submit-2.8.0-lin-x64.vcvplugin
  1. Don’t unzip the file — place the .vcvplugin file directly in your plugins folder. VCV Rack will extract it automatically on startup. You can find your plugins folder via Help → Open user folder.
  2. Restart VCV Rack completely after placing the file.
If it still doesn’t work, open log.txt from your user folder and search for “Submit” — it will tell you exactly why it’s not loading. Please share that line and I’ll help you fix it!
Quick question for the Windows users here: is anyone else having trouble loading the plugin? Several people on the VCV Rack community already have it running on Windows without issues, so I’m trying to figure out if this is a specific system issue. Any info helps — thanks!
works fine in windows here! great work, i love these :slight_smile:
Update v2.8.3: VCV Rack version
  • Chrono: HEADS parameter now shows configuration names (ALL, TRP, DOT, QTR, DUB, SUB) instead of numbers — also visible on external controllers
  • Code cleanup and performance improvements.
  • Drift: FINE knob now resets to 0 on double click (was -7)
  • Chrono: HEADS slider order fixed (SUB at bottom, ALL at top — matches panel)
MetaModule Port v1.1 — Chrono Update
What’s new:
-HEADS slider now snaps correctly to 6 positions (SUB, DUB, QTR, DOT, TRP, ALL)
-HEADS slider labels now visible on MetaModule
-CPU usage reduced from ~44% to ~37%
MetaModule Update v1.1.1 - Drift update
