Squinky Labs Mixer-8 Crashes the MetaModule
x0x 6pc.yml (12.2 KB)
XOX 6pc.vcv (3.2 KB)
See attached files.
I was modifying the 4ms x0x patch, and I tried replacing Pressed Duck with the Squinky Labs Mixer-8 to save some CPU. With the Squinky, the patch loads fine but when I press play, the Meta freezes and needs to be restarted.
(What is the point of this patch, you might be wondering? I want to set up an x0x drum kit to use with my Oxi One; I want all the pieces to have an Accent option, and I want the accent to be triggered by velocity from the Oxi. To achieve that, I need to delay the drum triggers so the trigger doesn’t arrive before the velocity has changed; I use a comparator to check whether the velocity is above a threshold. I haven’t added the MIDI>CV modules that I’ll need, because I have to do that on the Meta — you can’t do it in VCV and transfer them over.)
Thanks, will take a look
