Souped Up MIDI Controller
Im not against anything, rather I don’t understand what it is you are suggesting…
so my comments were around, only what I could guess you mean.
e.g. What does an “Electra One” like module mean?
the Electra One is a hardware device, its purpose comes from its hardware form factor.
its very different to the MM, doesnt even have eurorack functionality.
but, it was quite possible that I misunderstood what you meant, that you had some thoughts on something you would like, and just needed to add some ‘flesh to the bones’
as for whats there at the moment… well there is midi mapping, and also bi-directional midi fw 2.0.9 which I would have thought gives you the bi-directional mapping you need from controller to patch.
control of eurorack gear, I have to assume you mean via CV , can be done without outputs. just map the parameter knobs to something like an attenuator (which usually default to 10v input), then take its output to a cv out of the mm.
midi output, Ive not checked this recently, there is the CVtoMidi output module, but I believe this does not currently support CCs. I’ve seen numerous requests for VCV (core) MIdi CV → CC module.
Im not sure if this has been done yet… (its pretty trivial to implment)
so yeah, I don’t what it means for the MM being a “Souped Up MIDI controller” , like the Electra One - rather than ‘being against it’
perhaps it just means adding Midi CV → CC ? (which has been requested before)
