Sound Design Tools with MetaModule
Here’s the patch from this video:
The patch utilizes a scanner module to crossfade between 4 effects. Each effect has two macros per effect. Each macro, and the crossfader have its own associated LFO.
External audio path:
-External audio is input in audio input 1
-Audio is output on audio output 1
Internal audio path:
-Audio input 1 is fed to the inputs of the 4 effects: sample rate reducer, fixed fitlerbank, delay, and reverb.
-The 4 effects go into a scanner module which allows for crossfading between the effects.
-The output of the scanner module goes into a crossfader which is used as a Dry/Wet for the effect (mixed against audio input 1)
-The even and odd outputs of the fixed filter bank go into a crossfader to allow for morphing between even and odd harmonics
Internal CV path:
-LFO 1 modulates the scanner
-LFO 2 modulates sample rate, delay time, and reverb size
-LFO 3 modulates bit crush, delay feedback, and reverb decay time
MetaModule knob mappings:
A - Master dry/wet
B - Effect scan
C - Macro 1: sample rate, FFB center frequency, delay time, reverb size
D - Macro 2: bit depth, FFB even/odd crossfader, delay feedback, reverb decay
E - n/a
F - n/a
U - LFO 1 frequency
V - LFO 1 amplitude
W - LFO 2 frequency
X - LFO 2 amplitude
Y - LFO 3 frequency
Z - LFO 3 amplitude
The large knobs are for the main parameters where as the smaller knobs are for all of the modulation controls.
Sound Design Tools.vcv (3.9 KB)
Sound Design Tools.yml (14.9 KB)
The files for this post have been updated to run with our new firmware so that the sample rate and block size automatically switch to the recommended settings of 48khz/512. Enjoy! :smiley:
