Sickozell Sampler and Looper Plugins Needed
Multi-channel loopers (clockable) and samplers are highly needed. These samplers should be able to capture samples in real time, play them back, and allow changes to the start point and length of the samples.
The looper from this company also comes closest to the functionality I am looking for.
Yes I wrote to Fabio. He said okay with the licensing bit. I have informed @danngreen already. Hope we can see some of the modules one day! :slight_smile:
New member here. I also emailed Fabio and he said the “ metamodule doesn’t neither allow to read/write sample files or display waveforms,
so many of my modules would be unusable.”
Would it be possible to allow the meta module to read/write samples? I agree the sickozell sampler would be incredibly useful in the meta!
  • Allen
Displaying waveforms is already present in the v2.0-dev branch, i.e. we will have Scope modules and waveform viewers.
Reading files from within the plugin is also in v2.0-dev, but I’m not sure if that’s how the sickozell sampler works. If the modules need to read files from the SD Card or USB drive, then I’m working on that too, but it’s not solid yet.
I haven’t planned to support writing files in the initial v2.0 release, but it’s not much more difficult than reading.
Thank you @danngreen for your hard work on the development. With the MIDI channel functionality, this sampler will become possible, and the necessary features will make the meta module shine even more.
Hi all,
Is there a module in dev2 handling sample at the moment? After wavetable modules done, it will definitively be a killer module :slight_smile:
Best regards and rhanks to developers!
yep there’s the sickocell player or sampler modules, the voxglitch repeater or looper modules, and the bidoo canard module. those all do sample looping ok!
here is an example of me using 12 sample loops using the canard module in a single patch: 12x sample loop player
