Shortcuts for adjustment mode
Is there a possibility to add shortcuts for quickly switching between different knobs in the parameter adjustment mode for each module? My idea is that upon entering this window, without pressing any buttons, the encoder would rotate the parameters, and then by pressing a button + the encoder, one could quickly switch between the various knobs to facilitate building basic parameters.
Yeah, this could be better.
When you load a module that doesn’t have a mapping, Or load something that has a mapping, but has some knobs unmapped, and go into single module view, I wonder if in the single module view, everything should be mapped automatically. And if there’s more controls in the plug-in than knobs on the meta-module, it would create multiple knob sets automatically, And the main encoder would just be a quick turn up or down to knob set one or two/etc. Mind you this is just in the individual module view, Once you exit the module view, the main patch knob set would take precedence.
Also if you override the individual module auto map, it could have the new default mapping, saved and recalled with all new instances of that module in other patches, as an option to set new default in module settings.
yes~This is how I’m thinking, but I’m not sure if it will have any practical impact because, for me, when adjusting parameters, the screen is frozen, and I only need to handle the knob settings. Especially when setting up modules like sequencers,It can reduce a lot of button operations.
