Sequencer Phasing
Watch on YouTube
-The output of 2 modal synthesizers are fed into the Pressed Duck
-A kick, rimshot, and clave module are fed into the Pressed Duck
-The Pressed Duck’s main outputs are fed to channels 1 and 2 on MetaModule
-A Count is used as a master clock source
-The main output of Count clocks two step sequencers
-The reset output of Count resets both step sequencers
-All 3 outputs from the SEQ 3’s are fed into a dedicated sequential switch.
-The switches step through on the 1st downbeat of each sequence, going to the next
sequence at the start of each bar.
-The output of the sequences are attenuated and then quantized,
-After quantization the sequences are then sent to an octave module for final pitch value.
Metamodule Knob Mapping:
A - Kick volume
B - Rimshot volume
C - Clave volume
D - Bass volume (modal synthesizer #1)
E - Lead volume (modal synthesizer #2)
F - Reverb Amount
U - Compression amount
V - Feedback amount
X - Master volume
Sequencer Phasing.vcv (4.7 KB)
Sequencer Phasing.yml (19.5 KB)
HI there, is there a link to the file or am I missing something? :slight_smile:
Apologies, the files are there now!
Thank you so much,
I am very much a rank beginner, so I appreciate it.
BEst
Steelie
The files for this post have been updated so that they automatically load the recommended sample rate and block size of 24k/512. Enjoy! :smiley:
