Here’s a fun one from this week:
This patch revolves around the SCM’s ability to create funky shuffled grooves. The only knob broken out from the SCM is rotate. Slip, shuffle, and skip are dialed in to very precise ranges so that the groove sounds good at all rotation states. This creates a global knob for changing the rhythm.
-Main audio outputs on channel 1 and 2
-All drums are running into an 8 channel mixer
-A simple monophonic bass patch consisting of a square wave VCO, a VCF, and a VCA are running into the mixer.
-The mixer is then fed into a master distortion module
Internal Logic Path:
-Clocks from an LFO drive the QCD
-Outputs from the QCD drive the SCM, a hi hat, and a snare drum
-Outputs from the SCM clock all of the drums and the sequencer
-Voltages from a sequencer are quantized and sent to the bass patch
MetaModule knob mappings:
A - SCM rotate
B - Kick drum decay
C - Quantizer note offset
D - Bass filter cutoff
E - Bass filter CV attenuverter
F - Bass EG release time
Fyoocha Bop .yml (17.7 KB)
Fyoocha Bop.vcv (3.4 KB)
