Saving a duplicate changes sound
Beta firmware 12.2
When modifying previously saved patch in meta module and then duplicating and renaming it, sound immediately or after stopping and starting playback, changes. Sometimes with new patch file detected refreshed, pops up.
Seems like saving resets some settings on the modules.
At least Noise Plethora resets banks, DLD delay time was back to 50%, Dark Energys settings also changed. Djembe pots also reset to zero.
This is making me scared of saving:)
No one else have this problem?
if you can post a yml/vcv file for the patch where dan can easily reproduce the issue, he might be able to fix it
It does it in every patch. Just patch few modules together, save it, then modify it, duplicate and rename the patch. Stop and restart, and the sound changes.
And this was done with plugins that came with Meta module.
