Running four Sanguine Monsters Sphinx modules clocked by a QCD. The patch works correctly in VCV Rack, but on the MetaModule the Sphinx outputs produce nothing, and the module’s output jacks don’t appear as mappable when patching to panel outs.
- Plugin set: the 2026-09-09 bundle
- The plugin loads and the Sphinx panels render on the module, so it isn’t a missing-plugin case
- Clocking is fine — QCD Out 1 normals to channels 2–4, and the clock reaches Sphinx input 6
- Same patch in VCV Rack outputs gates and accents as expected
- Affects all three outputs:
OUTPUT_GATE,OUTPUT_ACCENT,OUTPUT_EOC
Happy to attach the .vcv and .yml if useful.
