Sampling on MM?
I think that everyone would agree that a comprehensive and stable sampling app would be a game-changer and would greatly benefit 4ms in marketing MM as a product. Any idea when one (or more) will arrive for MM?
I thought that was coming with v2.0?
2.0-dev has been here for a while now. I have been using it since I first bought MM.
4ms has been talking about porting theirs pretty much since MM was released. The earliest firmware versions even included a non-working plugin of it.
@danngreen Any idea when this will be released? I think it will definitely create more demand of MM!
we can certainly work with samples! ive had 13x 80s 48/16b wav files running at once in a patch no problem… but of course with some annoying caveats: bug in the canard modules only loads half the wav, and currently takes a while to start running patches that use a lot of samples.
i remember dan mentioned in some past thread that he had a version of the SMS somewhat working on the mm but that it still needed a lot of work and wouldn’t be available until around or after 2.0 stable is released. no matter what, patience is the key here… for now i can work with the caveats mentioned above.
also dan at some point mentioned the SMS’s ability to stream audio files (faster loading, and ability to play enormously long sounds), very excited for that!
