Is there a way to route CV to a virtual knob/parameter on a module that has no CV input?
In VCV Rack on desktop I’d normally use stoermelder CV-MAP or µMAP for this. Patch CV into the module, click the slot, click any parameter, done. But since stoermelder isn’t available on MetaModule, I’m not sure what the equivalent workflow is.
To be clear, I’m not trying to map a physical MetaModule knob to a parameter, I want an actual CV signal coming in from a hardware jack to modulate a virtual knob in real time.
Is there a compatible module that does this or is there a recommended workaround?
