Reset Patch to file
when you modify a patch, you need to power cycle the unit in order to get back to its original state. Reloading the patch doesn’t work because the changes are kept into memory while the unit is on.
I’d like to suggest an option where the changes are dump when you reload the patch or switch to another one. In essence with this option, to commit the changes you have to intentionally save the patch.
Alternatively, it could be an option to manually “reset the patch state to file”.
EDIT : I just realized there’s a “revert” option already. My bad!
