I’ve discovered that neither LPG or LLPG by Bogaudio appear to work properly when loaded into Meta Module. (seems like a possible scaling issue with the response control or similar)
Where is the appropriate place to report an issue with a 3rd party module that has “4ms Company” listed as the maintainer?
You could either just report here, or on the github repository that we use to build the plugins that we maintain: Issues · 4ms/metamodule-plugin-examples · GitHub
thanks!
Thanks for pointing me to the correct repository. I’ve created an issue there:
opened 01:08PM - 01 Sep 24 UTC
I've tried both creating a patch in VCV and locally on the module itself, and wh… enever I incorporate either of these two modules, they appear not to work properly on the Meta Module.
Specifically, when "striking" them with a trigger or gate, they do nothing until the lowest Response setting, and at probably the bottom 2-3% of the parameter just emit clicks.
I'll attach both the VCV patch and the MM patch so you can see the behavior. **_Mind your speakers when playing this patch on MM._**
Notice that when you play the patch on the module, you'll hear no audio unless you turn up the Cutoff or VCA amount. Setting Response to its lowest setting will produce clicks, but anything above roughly 2-3% just generates a constant tone or nothing.
[LPGExample.yml.zip](https://github.com/user-attachments/files/16828989/LPGExample.yml.zip)
[LLPG_Issue.vcv.zip](https://github.com/user-attachments/files/16828996/LLPG_Issue.vcv.zip)
