The Scope module in Rackcore will draw the waveform outside of the scope window if the input gain knob is too high. Similarly with the offset knob - it will draw the waveform outside of the scope window over the module itself. See attached screenshot.
Yep, I’ve seen that too. I haven’t gotten to the bottom of it – if I clip to the screen widget’s boundaries then it works for this module, but other modules like the CVFunk Ouros will be over-clipped (the widget on that module is a small square centered within the circle). I haven’t dove too deep into how Rack+Nanovg do clipping, so there must be something else going on that I’m missing…
I’m optimizing the graphics port now, so maybe I’ll figure it out soon.
