have a question. I built this patch in VCV, but when I open it on the MM v1.4.6, the pitch sounds different. Is there anything that can be done about this? Both are set to 48kHz. And by the way, that Ensemble Oscillator is such a fantastic piece of gear!
Ok I just updated the firmware to V2 beta, and here is the pitch good;)
-The only thing is i used the Nano font filter in the 1.4.6. version just fine
(was 84%) when I opened the same patch in the V2 it was overload.
MM V2 / VCV plugin v2.09
I’ve also discovered that if I completely rebuild the patch directly on the MM, it runs fine (at 75%) with the Nano module font. However, if I export the same patch from VCV to the MM, it no longer works (overloads).
