Pressing Auto-Map Knobs multiple times creates multiple copies of a knob mapping
Hi everyone,
I’m getting a bit lost with knob-sets and ended up pressing “Auto-Map Knobs” multiple times. Then when I want to delete the knob set I have to go to each parameter in turn, and saw that the parameter was mapped to the same knob multiple times. See attached picture. I had to delete each parameter mapping manually.
Initialise does not clear the knob-set mapping either.
This is on the 2.0-dev11 firmware.
Old post, I missed it, sorry.
I think there’s a valid use case for clicking Auto-Map multiple times and having multiple knob sets: you can then edit them individually or remove particular mappings as you wish.
But what would make this a better experience is if you could quickly clear/delete a whole knob set. Then if you accidentally did this, it would just be a few clicks to fix it.
