Cool modules from VCV Library - Rigatoni
Note, I had to do some heavy optimizing here and had to reduce some calculation quality so it can run on the MM. Still sounded fairly close to the original plugin to me so I’m sharing it (regarding the harmonic osc, Loom)
cc @danngreen
Notes:
I force oversampling off when you move it from VCV rack to MM
I reduce max partials to 32 (even if it says 64)
I have some other optimizations that make the stride parameters change the sound a bit differently, but what can you do, the MM is working so hard already
