Thank you so much for porting some of your excellent modules to the MM. Such a gift!. Really enjoying deploying Fugue inside the MM and will post something in the coming days demonstrating its use - very musical and intuitive. Have also been playing with chains of multiple interlinked Beat modules in VCV rack - really interesting way of creating reciprocal trigger motifs (gates triggering Bar/Pattern changes in other BEAT modules) - such riches. (Inevitably I’m going to ask: Any chance of getting BEAT into the Meta universe as well?)
Hi Stuart, really happy to have your collection on VCV and the Meta. It’s quickly become one of my favorite collections.
I’m having an issue with patches containing the Operator module. MM will load the patch and then the MM UI freezes. The Operator continues to output via the MM jacks but all MM navigation and window animation for the entire MM is frozen. The CPU does not look or sound like it’s overrunning and I’ve tried with various bit and block settings as well as the same patch with other osc’s to test. Thank you!
Edit: I should also mention I am using the Yasuhiko Fukuda syx bank. which leads me to thinking I should try to run it again in a sec with a different bank loaded to see if that is the issue.
Edit 2: so I tried the default bank and am experiencing the same issue.
Thanks for reaching out marsona! I’m glad you like the plugin, and am sorry about the issue. I’ll look at this later today. I’m planning on a new VCV build this evening and will send a MM patch in as well if I can get this addressed.
Hi Stuart, no worries and no trouble at all, I totally understand the nature of these things and really appreciate that you are putting in the work and making amazing modules for us to use.
Please no rush! I just wanted to point it out.
Also an update, I managed to get that patch to work randomly yesterday, I didn’t change any settings but for some reason it booted right up and worked fine for a bit. I’ll dedicate some time this week to a more comprehensive test for you to see if I can narrow down the issue / if there is one.
Really love Cycle as well, looking forward to diving into some of your other plugins when I have time.
Hi I’m just following up on this, so I’ve messed around a bit more and what i’ve found is regardless of the sysex file loaded ( ex default eno ) and mm settings the patch will load and play but as soon as you turn the encoder to nav away from the play button the patch freezes, I think it’s pretty much narrowed down to the “operator” as I tried the same patch below with a different osc and it will work.
