This update to Fundamental adds the presets/ folder to the plugin. This works with firmware v1.5.2 firmware v1.6.0 and later so you can load factory presets
may I ask for instructions on how to load the factory presets? I’ve downloaded the latest 1.52 update and Fundamental v1.5.2, but when I use the quantizer, there doesn’t seem to be any menu to adjust or load factory presets. Thank you, Dan!
Ah… sorry. Should have that fixed in a couple hours
Sorry about that! I just pushed Fundamental v1.6.0, which contains the presets.
It requires firmware v1.6.0, too. Sorry for the confusion.
Is firmware v1.6.0 imminent, then?
Nice. Was wondering if there’s plans to make Wavetable VCO work (I believe it’s missing) or if there’s some kind of difficulty with porting that plugin.
Edit: Yes, v1.6.0 is on the plugins page now (and in the .zip file)
Yes, we can do it now that we have filesystem loading working.
In the v2.x branch, the screen will work, too.
Same for WTLFO
Thanks, Dan~ Everything’s been so exciting lately!
+1 for WTLFO that would be amazing! Would we be able to import our own wavs?
