Plaits and Rings clones in 96khz
Noticing some odd behaviors in the Mutable clones running at 96khz.
In the plaits clone, modulating a parameter such as time with a slow triangle lfo results in noise during the middle of the sweep.
For rings, sending pitch cv from an Oxi one seems to generate many extra triggers- note that the in is not patched in this instance. Just cv straight to v/oct, which usually triggers a gate only when the sequence cv changes value.
I’ll try and save patches tomorrow to see if these bugs are reproducable on someone else’s rig. Changing settings back to 48khz seems to fix the issues.
