PERCALL - Bugs on choke function
Hi there,
I tried the Noise Plethora into Percall patch today.
I had 2 differents bugs related to the choke function :
  1. on both of them when I engage them I couldn’t switch them off (the choke buttons moves / even after swaping & reloading the patch)
  2. Choke 1>2 : chokes well channel 2 regarding the decay length of channel 1
    Choke 3>4 : channel 3 chokes “some” triggers" of channel 4 but is not related to decay length.
I attach the patch here
PLETHORA PERCALL.yml (6.4 KB)
i’m on FW 2.1.2
Thanks for your feedback !
Best
@hemmer might be able to check on this?
Can take a look, before I do I assume it works as you expect in VCV?
I have just tried out and it works fin in VCV.
Here is a simple VCV patch :
VCV PLETHORA PERCALL - CHOKE.vcv (1.6 KB)
Thanks!
Hi Hemmer,
Did you have a chance to have a look?
Thanks!
Hi there,
I’ve just checked and cannot reproduce either. I don’t 100% understand 1. but:
  1. choke can turn on and off for 1&2 and 3&4, the visual state and behaviour matches VCV and my expectations
  2. both 1&2 and 3&4 choke every time a new trigger comes in. to test i’m feeding a gate and a slightly delayed gate and plotting envelopes from 3 & 4 and 4 is choked every time 3 triggers.
Hi @hemmer,
Thank you for your feedback.
I still have the bug = Choke function is always ON no matter the position of the Choke control.
I recorded 2 videos showing the behaviour : 1 for channel 1>2 and the other for channel 3>4
4MS META - PERCALL CHOKE - Google Drive
I don’t understand this behavior
Did you try with the patch I uploaded?
Anyone else having trouble with choke control?
Yes I used your patch to check (needed to re-map outputs). One possible thing is the gates/triggers your sending might not be always sufficient somehow. Could you rule out by sending gates from a reliable LFO within the yml/patch to check?
Good evening Hemmer,
I tried both with :
  • 2 x square LFO
  • 2 x euclidean circles
    And same behaviour, the choke function is always ON.
I added 2 videos in the Drive : 4MS META - PERCALL CHOKE - Google Drive
Have a good evening
Am I the only one experiencing this ?
Would be nice to have some feedback as it’s a useful module
Yeah would be good to get confirmation as I can’t seem to reproduce at all. One of my favourite modules IRL!
You saw the problem in my videos with the choke function not going off?
I use the last META FW (2.1.7) and Plugins so it should be the same behaviour for other users.
Or I might soon going to be unable to stop choking :wink:
Thank you @hemmer for your follow up on this, I so want to use it !!!
Just so you don’t think I’m fobbing you off :sweat_smile:, here’s a video with me doing the same thing in VCV and MM. https://drive.google.com/file/d/1eHkF-cv4t65x7S1LFjAGfAJPi3KuPrSj/view?usp=sharing
Sound isn’t great, but at the end you can see the channel 3 (yellow) clearly choking the channel 4 blue when the setting is toggled on and off.
Start is same behaviour in VCV.
Firmware v2.1.3
Hi @hemmer,
Thanks a lot for taking time to do and upload a video.
The video was essential to identify the bug so thanks!
here the video : 4MS META - PERCALL CHOKE - Google Drive
The choke function ON/OFF works when you adjust that parameter in the menu (as you did) but NOT when it’s mapped to any of the meta knob.
I tried assigning to midi and it works fine.
Would it be possible to make it work with the meta knobs?
Unrelated question : how did you do to connect the meta to your screen ?
Have a great day
For me, the knobs also work but you need to be left or right of noon (0.5) to change it? I notice that Percall is a rare case where I haven’t used configSwitch (uses configParam instead), just for historic reasons - I suspect that MM handles explicit switches more naturally. I’ve opened a PR to fix: Update Befaco submodule to fix Percall choke switch by hemmer · Pull Request #547 · 4ms/metamodule · GitHub
I use an expert sleepers es-8, but any DC coupled audio interface should do the trick!
Thanks a lot !:folded_hands:t2:
Ok I get it !
I thought you could mirror the meta screen on another screen :sweat_smile:
Thanks @hemmer both chokes work :slight_smile: !
