Path Set: Free Ported
Find them here: Releases · Ericxgao/metamodule-pathset · GitHub
Ok’d by the original maintainer, patheros
Port of VCV Library - Path Set: Free
No expanders as MM doesn’t support them
IceTray cannot operate with the pitch shifters on, so I load them in off by default. However, if you are bringing over a patch from VCV Rack with the IceTray, it may still default to turning on pitch correction, which will tank your CPU.
TY. I thought Astro Vibe may stress the CPU but not really. Glass Pane will definitely be one you do not want to patch on the MM given the multiplicity of jacks :slight_smile: (Something glitchy on the UI in that one too)
Yeah I assume you will bring things over from VCV for that one…
Good catch on the UI bug, should be fixed in the most recent release
