Patch name doesn't immediately update after saving
When I save or rename a patch on the Meta Module, the patch name in the header bar doesn’t update until I move the encoder. It’s a little disconcerting to painstakingly enter a patch name using the MM keyboard and then see the header bar revert to “Untitled Patch 347.yml”
I just saw that! It’s fixed in v2.0-dev-11.1, and I think I fixed it in v1.6.7 (have to check)
Great! I just tried again in dev-11.1 and it looks like it’s fixed when I use the Move/Rename command, but not when I’m using Save on an unsaved patch.
Ah… right, I missed that case (initial Save)
