Hello there, I’m hoping to use the MetaModule as an octaphonic panner, panning incoming signals through a circular space with 8 speakers, possibly adding some room reverb. Any pointers as to which modules might be helpful, much appreciated! Thank you, Gideon
A matrix mixer. I think it’s the only way to process so many outputs. Bogaudio has an 8x8 mixer that should do the trick.
Indeed, the Hetrick scanner is a fine option as well, at least for crossfading one input through 8 outpus. So that basic function is covered; Rotational panning, with X-Axis is 1.0 - Next step is to figure out movement over the X&Y-axis, which would make the input ‘bleed’ to more outputs, and move away from strict crossfading, if you know what i mean?
agreed about the Hetrick Scanner. The Meta seems like an ideal module for this kind of thing with lots of options to try.
