Hi there. One of the outputs from the Audible Instruments Resonator module doesn’t seem to be working in MM. Here’s the simple patch that demonstrates it:
Res try.yml (5 KB)
I substituted Modal for Resonator and both outputs work.
Further testing shows that there is an output from both Resonator channels when connected individually, but when both channels are connected, the right channel is muted. Which is extremely weird.
