Firware 2.1.5. New plugin won’t preload when marked to do so.
when you set a plugin to ‘load on startup’, you have to then back out of the settings screen to make that go into effect. otherwise if you restart the mm right after turning that setting on for a plugin, it won’t auto load them.
Sorry, we left the “4ms-” off the start of the mmplugin file. You could rename your .mmplugin file from “ProducerPack.mmplugin” to “4ms-ProducerPack.mmplugin” or re-download it (all that changed is the file name)
Thanks was acting like Nano vs NANO issue from before. Thought it was a naming issue.
