Need Tips For Importing From VCV Rack
Hi - New user here. Sorry if obv.
I’ve created a patch on VCV using only devs found at MetaModule | Plugins. I’ve downloaded ‘all’ from that page and set them to autoload on the MM. Rebooted and confirmed they autoload. I also clicked-through to the VCV page and ‘Add All’ from the same list of devs to my VCV account.
When I create a patch in VCV I get a couple anomalies. A module such as in this example the Turing Machine does not load but I can add it manually. Also a module such as Elastika Sapphire does not load and also is not in the list of available manual modules.
Is a subset of the total modules from a dev available? Is there a list somewhere to reduce trial and error or am I doing it wrong?
If I hit a memory limit on load will that create the issues with modules not loading as well?
Any best practices or workflow I should be considering save doing all my composing on the MM?
Thanks!
Hi, not all plugins from vcv are ported to Meta, sappire’s elastika is an example, one way of checking is to go here - plugin page open a dev folder and hit the “modules” button this will show a list of available content that will be installed to meta, you can manualy filter out incompatible stuff from your vcv, there is not currently a filter in vcv shell, I think that will come in time
