Nautilus v2: A Complex Delay Texturizer
Based (conceptually) on the Qu-Bit Nautilus, this patch is a quad delay, reverb, and filter combo effect for creating complex, rhythmic, and evolving textures. Many of the parameters are named after those on the Qu-Bit module in order to give credit where credit is due.
PRIMARY FEATURES
  • Mono in to Stereo Out
  • Four Delays in a linear signal chain with ability to offset their delay time relative to eachother.
  • Stereo multifilter into Reverb are mid-chain to add color to the last 2 delays at end of chain.
  • Auto panning is built into final end of signal chain.
  • Clockable
  • Dry/Wet Signal control
PANEL IN
GATE1- CLOCK
GATE2- SONAR GATE [See Knob Set 2 for info]
CV1-AUDIO IN
CV2-FILTER FREQUENCY
CV3-DELAY TIME
CV4-DELAY FEEDBACK
CV5-REVERB (Fathoms) D/W
CV6-REVERB SIZE
PANEL OUT
OUT 1/2 - STEREO MIX
OUT 3/4 - WET OUT
OUT 5 - SPREAD RATE LFO out
OUT 6 - SONAR Envelope out
KNOB SET: MAIN
DRY GAIN - Adjusts dry signal amplitude(silence to +6db)
WET GAIN - Adjusts wet signal amplitude (silence to +6db)
DISPERSAL - Adjusts relative offset of delay times
SPREAD - Adjusts Pan Intensity of Wet Signal
SPREAD RATE - Adjusts auto pan rate
TIME - Adjusts baseline time value for all four delays
FEEDBACK - Adjusts all four delay feedback levels
FATHOMS - Adjusts reverb dry/wet
FATHOMS REPLACE - Adjusts Reverb ‘replace’ value
FATHOMS DETUNE - Adjusts Reverb detune function
FATHOMS BRIGHT - Adjusts brightness of reverb
FATHOMS SIZE - Adjusts reverb size
KNOB SET 2 : FILT/OFFS/SONAR
OFFSETS B/C/D - manually sets relative offset value for each delay time. The scale of these offsets is controlled by ‘DISPERSAL’ in the main panel. These offsets are bipolar.
SONAR PING - The Sonar feature is a gate controlled envelope modulating the resonance of the multi-filter. This knob controls the intensity of that envelope and, thereby, the amount of resonance triggered by it.
SONAR A/D - Control the attack and decay values of the ping envelope
SONAR FEEDBACK - Scales how much the sonar envelope also momentarily modulates the delay feedback for each delay [NOTE: I’m still working out this feature]
LP/BP/HP - Toggles which filter type is used in the delay chain
FREQ - Adjusts the filter frequency mid-chain
FREQ Q - Adjusts the baseline resonance for the filter. This is bipolar to offset incoming pings from Sonar as well.
FILT DRIVE - Adjusts the drive of the filter signal, adding grit and volume to the delay signal.
PERFORMANCE
This patch reliably runs on my MM around 80% CPU power. That leaves very little overhead at times, so so you may need to scale down your bitrate should you run into any issues with CPU overload.
Enjoy!
NAUTILUS v2 [NVGTR].yml (16.3 KB)
NAUTILUS v2.vcv (4.0 KB)
