MSM Bitcrusher Patch
This patch uses our XOX drum modules, a mono synth, and a bit crusher to create a rugged little groovebox.
  • Main audio outputs are on channels 1 and 2.
  • A mono synth is constructed from an Even VCO, a Liquid Filter, and a Dual Shaped Envelope VCA.
  • The drum sources are Kick, Snare, and Maraca.
  • The Maraca is routed through an Accent Module.
  • The entire mix is fed into an MSM Bit Crusher and then into a Master Volume Attenuator.
  • A main clock from a Multi LFO is fed into a QCD, driving clock and reset signals for both Sequencers.
  • The Drum Sequencer triggers all drums, as well as a Bassline pattern and a quarter-note accent pattern for the Maraca.
  • The raw voltages from the 16-Step Sequencer are offset, attenuated, and quantized before being sent to the Even VCO. This provides the user with Sequencer range and note offset control for the Bassline.
MetaModule Knob Mappings:
A - Bass filter cutoff
B - Bass envelope filter depth
C - Bass filter resonance
D - Bass amplitude decay envelope
E - Bass filter decay envelope time
F - Bass volume
U - Kick volume
V - Snare volume
W - Hi-hat volume
X - Sample rate
Y - Bit depth
Z - Overdrive
Bitcrushing Rev A.vcv (4.3 KB)
Bitcrushing Rev A.yml (36.4 KB)
this one is so fun. awesome work!
The files for this post have been updated to automatically select the recommended sample rate and block size of 48k/512. Enjoy! :smiley:
