Modules keep on crashing
Updated to new fw and plugins this morning and been having issues all day
Pretty much every module I create keeps crashing / freezing when using any of the mapped buttons
So far tried beefaco, 4ms , fundamental, nano
Sometimes it works for a bit then just crashes and I get a high pitch output
Getting 67-70% cpu load sample rate at 3200
Block 64/32(on some )
Furthermore I reinstalled the old fw/plugins I get longer times before same thing happens the unit just freezes
Presets saved on SD CARD btw
Any help greatly appreciated
Can you send a patch file that crashes?
What do you mean by “mapped buttons”? For mapping to a jack?
Or are you talking about the Knob Sets page?
Sure Thing , I’ll attach to this
Also I mean the button set that has been mapped to the mm unit
Sometimes it works fine but then either one of 3 things happen
  1. The patch crashes - it keeps playing but nothing is responsive and needs a restart
  2. The patch just stops playing and gives off a high pich noise
  3. The buttons stop responding and it just goes into overdrive and crashes
Thank you
Noize Boys2.yml (11.2 KB)
today ive tried to reset the MM module
then re-installed everything to new sd card
still having the same issues , but i now get longer play times at least 10min of usage before the module shits itself and crashes
tried to recreate same patch in VCV which works fine in VCV but as soon as I move it to the MM unit it crashes again afer 10min of jamming
Cheers
Ok, that patch crashed for me, too.
I’m looking into the bug and might be related to the NoisePlethora Program Select CV jacks
Do other patches that you had problems with also contain the Noise Plethora with the Program Select jacks patched?
Hi Dan
Thank you for your reply
Other patches did not have any Beefaco modules but still crashed , most of these were happening when using the button sets
Thanks
Ok, if you can send more patch files that crash I’ll check them out.
“Button Sets” = Knob Sets?
Are you saying it crashed when you changed Knob Sets?
Hi Dan
Will send some through when I’m back home
I meant that the unit crashed when using any of the encoders mapped to anything not particularly when chancing the button sets but when actually using the buttons , also noticed that the patches on which this happens run at approx 70% cpu power
I have avoided using beefaco today and had no real crashes , just one after about an hr of operation but otherwise was good
I reformatted the SD , I’ve reinstalled firmware and plugins and created new patches
